Dashboarding
How to get cpu used by same process on different host?
Naveen
Guide
I have a process called xyz.exe running on 3 different host Host1. Host2, Host3 so I want to get CPU used by this process on 3 host in single graph.
5 REPLIES 5
AntonPineiro
Are they under same host group?
Best regards
Hey @AntonPineiro yes it's under same hostgroup.
then you can do it this way (use name or tag of process group in filter):
Alanata a.s.
@rastislav_danis Great minds think a like 🤗
Yosi_Neuman
Hi @Naveen
IMO you can use builtin:tech.generic.cpu.usage for that
HTH
Yos
