29 Sep 2023
12:32 PM
03 Oct 2023
07:16 PM
AgataWlodarczyk
Hey there,
I'am just stepping into the depths of Dynatrace and now I got a problem:
How to ingest alphanumerical values into Dynatrace and display them on the dashboard?
1. this works because the value is numerical
/opt/dynatrace/oneagent/agent/tools/dynatrace_ingest "anz_bla.count `ls -ltr /tmp/anz/bla* | wc -l`"
This script counts files in /tmp/anz/. With this metric (anz.bla.count.gauge) I can use nearly any tile I want.
2. that doesn't work, because of the string value
/opt/dynatrace/oneagent/agent/tools/dynatrace_ingest "timestamp_host `date`"
There is no reaction in Dynatrace.
Now my questions:
How can I ingest alphanumerical values? date is only an example.
How can I display alphanumerical values in dashboards? Table, Textbox, or something else. Graph, I assume, would not work ;-). The workaround with writing a log file should work, but I cannot test this in my sandbox.
Is there a way to manipulate values when they come in? I.E. Value comes in -> Script changes input "OK" to 1 -> manipulated value is being used by Dynatrace.
Thanks a lot in advance.
Martin
02 Oct 2023 09:05 AM
Hi @freudi,
It sounds like you want to ingest dimensions with your metric. Something like a status code "OK" would make sense here. But a timestamp here would not make sense, as it would increase the number of unique dimension key-value combinations and likely cause you to run into dimensionality limits.
The agent accepts data according to the metric ingest protocol. Adding a status code dimension may look like this:
/opt/dynatrace/oneagent/agent/tools/dynatrace_ingest "my.http.status.metric,status=${status} ${value}"
I hope this helps answer your question.
Take care,
Nick
07 Mar 2024 04:46 PM - edited 08 Mar 2024 05:20 AM
HI @nickvogt
Well, Its works, but i need few more information's in my problems.
I want to see the host name and port number details as well in my problem ticket created.
/opt/dynatrace/oneagent/agent/tools/dynatrace_ingest concurrent.connection.small.metric
However I would like to pass few variable like hostname port number to see these details in Problem generated.
How can I do that
how should I see that hostname and port number that I am passing through my script.
