How to set default colour for honeycomb?
Not quite sure if someone has workaround this already? or needs a RFE to be raised?
The reason to get a default color, is it will ease our job in such scenario:
  • I got a field that has 9 possible value, if the field is of any value from 2nd value to 8th value, honeycomb needs to be red; if the field is of 1st value, then makes it green.
  • Then instead of make 9 rules in the tile's->visual->color->custom color there, I would just need 1 rule.
    Also, in future, customer might have some update that cause the field to has new 10th value, 11th value etc etc....Each of these new value also needs the honeycomb to be in red.
marco_irmer
Champion
If this is a DQL tile then you could use the fieldsAdd command combined with using if statement at the end of your DQL query to create a new field indicating the color that should be applied.
