I need help creating custom dashboards
jbenavidez
Newcomer
Good afternoon community,
I need to create two custom dashboards in my environment. I am new to the world of dynatrace and I need help to carry them out
REPORT 1 – Generation from a Supplier's API
Validation of a Supplier's SLA
REPORT 2 – Generation from the loss of connectivity
Connectivity validation at the time of service authentication
A. Servers by country (graph an example)
I look forward to the answers.
Thank you
jbenavidez_
bsnurka
Dynatrace Advisor
Dynatrace Advisor
Hey @jbenavidez here are some resources to get you started!
Since both of the reports you are looking to create relate to validation of your application health (supplier API & Servers by country @ time of auth), I would suggest starting off with creating the data views you are looking for directly from a Grail query, and then use that same Grail query to add the tile onto your Dashboard.
As you & your team are the only ones who know your app stack in entirety, it would be difficult for us to provide complete answers to your question in the forums, hence the resources to give you a starting point!
dannemca
Incrementing @bsnurka answer, I would like to refer to SLO creation, to solve the first report scenario:
https://docs.dynatrace.com/docs/platform-modules/automations/service-level-objectives/configure-and-...
