Dashboarding
Is there a way to create a traffic light dashboard on host health in Dynatrace managed ?
I would like to make a dashboard showing host health using a traffic light chart.
I've seen that dynatrace managed provides some default chart for this purpose. But this chart does not show the host name. It is just a link to default host dashboard.
Is there a way to achieve that ?
Best Regards,
peter_zahrer
Dynatrace Champion
Dynatrace Champion
Hi Bouare,
if you want to show the health of a specific host, please go to the host view, and filter for the required host. Click the "Keep this filter" button in order to be able to pin the tile. Here is a good guide: https://www.dynatrace.com/support/help/monitor/das...
The tile doesn't display the host name per default, but you could adjust the title of the host list which will also then show on the dashboard
Peter
Hi Peter,
Your hint gave me an idea and I managed to get it done.
Thank you.
Best Regards,
Fousseyni
