06 Aug 2020 11:21 AM
Right now we only see the possibility of doing it through the managment zone.
If it cannot be done, there is an alternative that can be implemented to do it.
06 Aug 2020
01:22 PM
12 Feb 2024
10:49 AM
IzabelaRokita
At the dashboard level there is currently no solution for that. Once your on the problems page you can filter it out as you see fit but you the functionality of pinning that with the filters to the dashboard is not available.
Very interesting use case tho. I would recommend tossing in a RFE:
https://community.dynatrace.com/t5/forums/postpage/board-id/DynatraceProductIdeas
07 Aug 2020 11:53 AM
Hi Oscar,
While this direct functionality is not possible, I would like to present a close alternative that is possible. This involves using the "entity lists" views (Transactions & Services, Hosts, Databases). You can filter these lists by "Problem Impact" and set it to Impacted, then pin this to your dashboard.
What you end up with is a breakdown of problems per entity type (which also supports the additional Management Zone filtering).
Of course this is not an exact number of Problems, but rather entities of each type that are part of Problems (so we may have 3 Services part of 1 Problem) but it is a popular alternative to achieve that breakdown of the impact. With the Problem tile next to it, it offers a very readable layout.
Please, also feel free to raise this as an RFE as Chad suggested earlier.
I hope this helps.
Best regards,
Radu
09 Sep 2021 04:16 PM
I like your idea, but its not perfect since you cannot Pin process groups (Technologies page) to a dashboard, so processes and custom devices with Problems would not be presented in dashboard.
