Dashboarding
KeyUserAction Performance Metric Distribution TO Dashboard
gbaudart
DynaMight Champion
DynaMight Champion
In a dashboard, I would like to monitor the response time distribution of a key user action. We can view it from the action menu, but I can't find a way to add it to a Dashboard.
Do any of you have an idea?
Dynatrace Partner - Professional Certified - DynaMight
6 REPLIES 6
Yosi_Neuman
Hi @gbaudart
You can utilize builtin:apps.web.action.responseEnd.load.browser and builtin:apps.web.action.responseEnd.xhr.browser metrics
HTH
Yos
Thanks @Yosi_Neuman,
But I would like to have the view with a number of actions distributed by ResponseEnd time. With the same view as that of the action menu.
the “heatmap” view is different and is more “complex” for my interlocutor.
Hi @gbaudart
Now I understand better what you are looking for , my bad.
Don't know a way to show outliers on dashboard 🤔
Hope someone else have a better answer than me
All the best and stay safe
Yos
gbaudart
DynaMight Champion
DynaMight Champion
Thanks to @Julius_Loman for the answer to the RFE: https://community.dynatrace.com/t5/Product-ideas/RFE-dashboard-tile-for-KeyUserAction-Performance-Me...
This solution is a good workaround while waiting for the possibility to consult RUM data in GRAIL 🙂
@gbaudart  You are welcome. It's not the same output (and it's not possible to display it in the same way), but it is at least some method to display distribution on dashboard which will be still valid for Managed customers anyway.
Mizső
Hi Folks,
Maybe it is not the same. It could be an alternative solution also. 😉
Best regards,
Mizső
