Dashboarding
Prediction within Existing Reporting or Dashboarding Module
alex_kanjirakat
Newcomer
Is there a way to chart predictive analytics within Dynatrace Console without hitting the time series API
3 REPLIES 3
miguel_balsa
Dynatrace Mentor
Dynatrace Mentor
Hi @Alex J.
Unfortunately, this is not possible at the moment in Dynatrace, you will have to use the API.
Although, notice that the predicted data is used in the AI problem analysis as well. If the actual traffic highly differs from the prediction, the AI will raise a problem.
Hope it helps!
Thanks ! While calling the API to get predictive data, whats the model that's being used and whats the accuracy
AgataWlodarczyk
Community Team
Community Team
You can do this with the Power Up Chrome extension.
https://github.com/dynatrace-oss/DynatraceDashboardPowerups#forecast
When passion meets people magic and innovation happen.
