03 May 2019 10:28 AM
03 May 2019 12:38 PM
tileType of mentioned tile is "PROCESS_GROUPS_ONE"
03 May 2019 01:10 PM
The metric "Processes - Request Count" filtered by a process group tag should give you what you're looking for, right?
03 May 2019 01:37 PM
this will produce custom graph tile, where you cannot decide specific lines per process. when you choose top list, then you can see process name but without history.
process group tile was pretty useful for us (we can see if one process processes less requests than other in one tile), is there a good reason why it was removed ?
03 May 2019 01:41 PM
All our decisions are based on thorough consideration. In this case those reasons are supportability and performance/stability.
If I understand you correctly, you're missing the chart legend to see which color corresponds to which process. This will be added in the course of the following months. Until then, I'd advise you to put a toplist chart next to the line chart on your dashboard.
03 May 2019 01:49 PM
ok then, we will wait. should we expect that existing configured tiles in customer's dashboards will dismiss in some of next releases ?
03 May 2019 01:50 PM
Yes, those will be transformed into regular custom charts as well.
