08 Aug 2025
02:55 PM
01 Dec 2025
11:48 AM
Michal_Gebacki
we are using infrastructure mode and have only access to classic dashboard
i am trying to group processes. and trying to find out unusual process to highlight
for example. Tag OS process instance a tag , scanning processes another tag, and others
builtin:tech.generic.cpu.usage:splitBy("dt.entity.host")
:partition("processgroup",value("antivirus",
in("dt.entity.process_group_instance",entitySelector("type(PROCESS_GROUP_INSTANCE) AND tag(~"pgn:antivirus~")"))))
but i get
Metric selector parse error: invalid value condition `in("dt.entity.process_group_instance",entitySelector("type(PROCESS_GROUP_INSTANCE) AND tag(~"pgn:antivirus~")"))`.
basically use tag as dimension to group metrics in custom manner . any workaround
08 Aug 2025 11:56 PM
Hi @Vijayt,
Maybe I do not understand what would you like to achive with partition transformation
Filter for specific tag on process goup instances:
builtin:tech.generic.cpu.usage:parents:filter(and(or(in("dt.entity.process_group_instance",entitySelector("type(process_group_instance),tag(~"PG:Apache Web Server~")"))))):splitBy("dt.entity.host","dt.entity.process_group_instance"):sort(value(auto,descending))
I hope it helps.
Best regards,
János
09 Aug 2025 05:44 PM
well. i can get specific process instance metric. but it will show only specific process results .
let us say if i want to group similar process in 4 groups . then i want specify manual via partition transformation . so that i can show .
can entity selector or tags be used in partition condition ?
12 Aug 2025 05:43 AM
Hi @Vijayt
I thnik you can use for this the entity selector and tags. Lets assume you have 4 tags for 4 groups.
pgn:antivirus, pgn:apache, pgn:osprocess, pgn:scanning. Use the automatic tagging by rules or manual tagging ( not recommendded).
Metric expression could be:
builtin:tech.generic.cpu.usage:parents:filter(and(or(in("dt.entity.process_group_instance",entitySelector("type(process_group_instance),tag(~"pgn:antivirus~")"))))):splitBy("dt.entity.host","dt.entity.process_group_instance"):sort(value(auto,descending))
builtin:tech.generic.cpu.usage:parents:filter(and(or(in("dt.entity.process_group_instance",entitySelector("type(process_group_instance),tag(~"pgn:apache~")"))))):splitBy("dt.entity.host","dt.entity.process_group_instance"):sort(value(auto,descending))
builtin:tech.generic.cpu.usage:parents:filter(and(or(in("dt.entity.process_group_instance",entitySelector("type(process_group_instance),tag(~"pgn:osprocess~")"))))):splitBy("dt.entity.host","dt.entity.process_group_instance"):sort(value(auto,descending))
builtin:tech.generic.cpu.usage:parents:filter(and(or(in("dt.entity.process_group_instance",entitySelector("type(process_group_instance),tag(~"pgn:scanning~")"))))):splitBy("dt.entity.host","dt.entity.process_group_instance"):sort(value(auto,descending))
I use partition transformation for value partioion only eg. from the documentation:
:partition(
"Action duration",
value("slow",gt(200)),
value("fast",lt(100)),
value("normal",otherwise)
I hope it helps.
Best regards,
János
18 Aug 2025 05:39 PM
thanks Mizso for the reply. yes i use same method
