first contentful paint (FCP), Time to first byte (TTFB)
fstekelenburg
DynaMight Pro
DynaMight Pro
Allthough it's mentioned in RFE : CrUX metrics, and visible in details of the Contributors breakdown graph ((K) in below image), I can not pull the first contentful paint (FCP),  metric with the USQL, not use it in a custom chart.
The Time to first byte (TTFB) can be used in a custom chart, but is not found in the USQL either?
If this is by design, are there plans to make this available or are there reason not to?
Kind regards, Frans Stekelenburg                 Certified Dynatrace Associate | measure.works, Dynatrace Partner
The_AM
Dynatrace Champion
Dynatrace Champion
Hi @fstekelenburg ,
You are right, it seems that those two metrics do not appear on the structure for the user action table over USQL:
https://www.dynatrace.com/support/help/dynatrace-api/environment-api/user-sessions/user-session-stru...
It may be that both are not yet metrics exposed on the Metrics API v2, as I could not locate them there either.
I recommend opening a product suggestion with this request.
Andrew M.
francopapp
Dynatrace Participant
Hi Team,
You can find Time to First Byte on USQL as Response Start (useraction.responseStart)
