segment data is not populated in dashboard
heramb_sawant
Organizer
Hi Team
I have created segment to get the cluster name list , saved segment successfully.
When i select the same segment from dashboard, it does  not show list of clusters(entity name i.e cluster names) to apply as filter on dashboard data.
any idea what I am doing wrong.
Please help.
Heramb Sawant
Peter_Youssef
Leader
Hello @heramb_sawant 😊
Check the management zone and Dashboard configurations as well.
Make sure:
  • Management zone configurations are properly configured to include all target monitored entities.
  • The dashboard is mapped to the target management zone properly.
  • You have sufficient privileges to view the related monitored entities within the target management zone.
All the best && Hoping it helps.
BR,
Peter
RomanW
Dynatrace Champion
Dynatrace Champion
Hi Heramb!
I'm currently working on providing a "How to setup segments for K8s" guide in the documentation, which would cover your exact use case.
You successfully managed to configure a segment to contain the monitored entities, but not yet the signals emitted by those.
This can be achieved by adding an "All data" include for metrics, logs, events, etc. with a condition for k8s.cluster.name = prefix*
I will further provide a link to the "How to..." guide, once its published.
