Developer Q&A Forum
Interesting Behavior when using queryExecutionClient.queryExecute
DeeJay
Frequent Guest
I recently watched "A Practitioners Guide to "Dynatrace AppEngine: Everything thinkable is now possible" https://www.youtube.com/watch?v=D5SDmLx6Aj4. where Stefan Wassebauer did a technical demo of fetching dt.entity.service and getting the called and calling services.   I thought I would replicate his work to cement my knowledge.  Without the code and some of the DQL being off screen.  I started with Notebooks in my environment to make sure I knew where to start.
This is the DQL that I ended up with:
fetch dt.entity.service
| fieldsAdd num_callers = arraySize(called_by[dt.entity.service]), num_called = arraySize(calls[dt.entity.service])
| filter num_callers > 1
| filter num_called > 1
| limit 20
when I added this to my code for app Engine
export default async function () {
const result = await queryExecutionClient.queryExecute({
body:{
query: "fetch dt.entity.service | fieldsAdd num_callers = arraySize(called_by[dt.entity.service]), num_called = arraySize(calls[dt.entity.service]) | filter num_callers > 1 | filter num_called > 1 | limit 10",
requestTimeoutMilliseconds: 30000,
I found that I was only getting 1 record returned,  after a little experimenting with different DQLs including some Logs,  I found I needed to add a ", from:now() - 100d" into my DQL,  I am only a couple of months into working with Dynatrace and DQL is still new to me but I don't understand why I would need a time range in my DQL when working with dt.entities.  Can someone point me to the explanation of this?  Code change to make it work
body:{
query: "fetch dt.entity.service , from:now() - 100d | fieldsAdd num_callers = arraySize(called_by[dt.entity.service]), num_called = arraySize(calls[dt.entity.service]) | filter num_callers > 1 | filter num_called > 1 | limit 10",
gilgi
DynaMight Champion
DynaMight Champion
@DeeJay ,
Could it be that it's just because you don't have services with both number of callers and called services are greater than 1 in the whort time period?
I would suggest first display the values without increasing the timerange to make sure its correct.
DeeJay
Frequent Guest
@gilgi
Thanks for your comment,  the issue I am having is caused by an assumption on my part.  I was testing my DQL in Notebooks and I assumed the time range was the same as the default in my appEngine app.  By default a new Notebook Query Grail on my system is Last 7 days, and clearly in the queryExecutionClient.queryExecute the time range is less.
The other assumption I was making is that a dt.entity.service didn't have a time range but when I did a
describe dt.entity.service in my notebook,  I found the lifetime field which is a TIMEFRAME which makes sense now that I think about it.
