How to check if a Synthetic Monitor location is offline?
Wyatt
Visitor
Is there any API call that will tell me if a synthetic location is online or offline?
"locationId": "SYNTHETIC_LOCATION-xxx",
"status": "location_offline",
I've tried 'GET - api/v1/synthetic/locations'... but this will just tell me if a location is disabled/enabled. I've found that enabled locations can also be offline.
"locations": [
"name": "Location Name",
"entityId": "SYNTHETIC_LOCATION-x1",
"type": "PRIVATE",
"status": "ENABLED"
"name": "Location2 Name",
"entityId": "SYNTHETIC_LOCATION-x2",
"type": "PRIVATE",
"status": "ENABLED"
-Wyatt
HannahM
Dynatrace Leader
Dynatrace Leader
There are several dsfm options that are helpful here, they are all related to utilization of the Synthetic engine
dsfm:synthetic.engine_utilization
dsfm:synthetic.browser.engine_utilization
dsfm:synthetic.http.engine_utilization
dsfm:synthetic.http_high_resource.engine_utilization
You can find them mentioned here in our private location details documentation. They can be retrieved using the metrics v2 API
There are also a couple of location metrics that you may be interested in.
builtin:synthetic.location.node.component.healthStatus
builtin:synthetic.location.healthStatus
