Dynatrace API
View Kubernetes metrics in Power BI
ayamaya
Contributor
How can I see kubernetes metrics and bring them to power bi
robert_schausbe
Inactive
You might take a look at the metrics query API v2 (https://www.dynatrace.com/support/help/dynatrace-api/environment-api/metric-v2/get-data-points/) which enables you to query metrics (output either json or csv)
