Dynatrace Managed Q&A
Connecting Dynatrace Managed Cluster (Online) With Mission Control
zaid-bashir
Advisor
We are trying to establish communication between our Dynatrace Managed cluster and Mission Control, but we are encountering connectivity issues. The current network flow is structured as follows:
Dynatrace Managed Cluster  → Proxy VM (Reverse Proxy) → Enterprise Proxy → Mission Control
We would appreciate your guidance on the recommended reverse proxy service to configure on the Proxy VM and the proper way to set up this communication path.
Note: We attempted to use IIS with Application Request Routing (ARR) on the Proxy VM as a reverse proxy, but it did not work as expected.
I addition to that when we are using wget to download the managed installer, its giving us the following issue:
connecting to <Reverse-Proxy-IP>... Connected.
Failed Reading Proxy Response: Success.
Note that we are able to curl from Reverse Proxy to Dynatrace Mission Control via Enterprise Proxy.
radek_jasinski
I haven’t come across any dedicated documentation or recommended reverse proxy specifically for communication between Dynatrace Managed and Mission Control. I recommend opening a support ticket with Dynatrace to get official guidance on this scenario.
Have a nice day!
