Deep monitoring not enabled
Abidyaseen
Advisor
 Hi Team,
We are encountering an unusual issue after installing OneAgent on three of our domain controller servers. Upon verifying the processes discovered out-of-the-box (OOB), I noticed that a critical process, Microsoft.ActiveDirectory.WebServices.exe, has been identified on all of them.but the deep monitoring is not enabled due to issue in internal configurations
I attempted to manually enable deep monitoring for this process, but it did not start,  Since this process is critical for monitoring, please advise on the next steps.
4 REPLIES 4
AntonPineiro
I would say, enable deep monitoring, be sure project injection is enabled and restart process.
Best regards
I did enable deep monitoring manually, but the issue did not resolve. i have requested a restart from the client for the particular process lets see
Hi Abidyaseen,
If restarting the service doesn´t fix the problem, try to reinstall OA.
Hope it helps.
Elena.
Abidyaseen
Advisor
The issue resolved after restart thanks
