22 Jan 2024 08:28 AM - edited 22 Jan 2024 08:29 AM
So in Dynatrace Managed, there is a scheme where the server containing OneAgent will send monitoring data to the Cluster ActiveGate on port 9999. Then, the monitoring data from the Cluster ActiveGate will be forwarded to the managed cluster on port 443. Is that correct?
Now, my questions are:
Thank you in advance.
22 Jan 2024 09:23 AM
In Dynatrace Managed, a typical configuration involves the OneAgent sending monitoring data to the Cluster ActiveGate on port 9999. This data is then passed from the Cluster ActiveGate to the Managed Cluster on port 443. This flow is actually designed to be unidirectional, with data moving from the OneAgent to the Cluster ActiveGate and then to the Managed Cluster, without any return flow that changes configurations on the application server.
Dynatrace emphasises the security of data in transit and at rest. This typically includes encryption and other security protocols to ensure that data remains confidential and is protected from unauthorised access or leakage.
Radek
22 Jan 2024 09:27 AM
Thank you, Radek, for your explanation.
Is there any official documentation related to your statement that I could refer? So, if there are potential customers who ask, I can show them the official documentation. I have tried searching but have not found anything suitable.
Thank you in advance for your assistance.
22 Jan 2024 10:26 AM
Unfortunately, I do not know if there are official documents. It is best to ask within the support ticket.
