Dynatrace Managed Q&A
How does OneAgent auto-update work in an offline Dynatrace Managed cluster?
g_ciret
Contributor
Hello everyone!
My customer chose to deploy Dynatrace-Managed in offline mode (no connection to Mission Control).
With this kind of configuration, we will have to upgrade the Dynatrace server manually.
But do we also have to update the OneAgent manually or does the auto-update system work without Mission Control?
Does the OneAgent get the last version from the Dynatrace Managed server to update the hosts anyway?
Thanks for your help.
Radoslaw_Szulgo
Inactive
Together with Dynatrace Cluster updates you will receive OneAgent and ActiveGate updates via email. This needs to be applied to your Dynatrace server and will be added to your repository of available updates.
Once new OneAgent update is available your existing hosts will be notified of it. This should tell you more what are the options - exactly the same as in SaaS or Managed online license:
OneAgent update
Hope you find it helpful!
Senior Product Manager,
Dynatrace Managed expert
Thank you Radoslaw for your quick answer.
Very helpful.
