Dynatrace Managed Q&A
Is it possible to integrate with Dynatrace screen (not dashboard) without login?
jungwan_kim
Dynatrace Guide
Dynatrace Guide
Hi Team,
My customer wants to open the Dynatrace screen without a login on other product screens using a link.
If it's impossible now, is there a plan to add this function?
The customer does not have a system for SSO.
Best Regards,
Julius_Loman
DynaMight Legend
DynaMight Legend
At the moment you can't view problems without login. Without login only selected shared dashboard can be displayed and they can have the number of problems on it (just the number). I'm not aware of any plans to give anonymous access to any parts of Dynatrace UI besides publicly shared dashboards.
A solution would be to use the Dynatrace API to fetch the current problem status and write a simple web app for that.
Hi Julius,
Thanks for your answer.
I will guide the customer with your comment.
Best Regards,
Jungwan
