26 Oct 2023 11:37 AM
I Have 4 hosts monitored and one of them goes offline. In Monitoring tab, it said Oneagent is offline but when I checked Dynatrace oneagent still running in the host process. Oneagent is running on Windows Server 2008 R2 (64-bit) and I have tried restarting oneagent service via oneagentctl nothing changed. Any suggestion or Idea to get it back online I left it offline for 70+ days
26 Oct 2023 12:07 PM
Did you checked the network connectivity? which AG is supposed to receive the traffic from that agent. try also to restart dynatrace services from services window.
Islam
27 Oct 2023 04:38 AM
Hello Islam,
I tried to run .\oneagentctl.exe --get-server on the unmonitored host and got this "Encountered malformed line - key-value separator not found" I ran this on a normal host and it was fine only for this one host. Any idea how to fix this issue
Thank you for your reply
27 Oct 2023 11:48 AM
I think the easiest way is to reinstall the agent again on the host with the latest update. or you can open a support ticket to go through the troubleshooting.
27 Oct 2023 11:52 AM
Thank you for your suggestion I already opened a support ticket, If it comes down to reinstalling the agent that is fine by me
