Dynatrace Managed Q&A
Problem duration metric sorted by longest duration
Khejazi
Guide
Hi all,
I want to create tile in dynatrace managed dashboard to show top list of problems with longest duration in a specitic time of period sorted descendingly
Any support how to do this?
I tried to filter problems and sorted by duration and then pin to dashboard, but it is showing me a single value and i cannot configure it in Data Explorer.
5 REPLIES 5
ChadTurner
DynaMight Legend
DynaMight Legend
If you are using the Gen1/2 Problem page and you save the tile, it will only save filter constructs and time frames, not sorting preferences on the table view. Additionally the tile will only show you a problem count. If you want a table version say a top 10 list, you will need to do this in the Gen3 UI with the new problems page:
Granted this is in a Scatter plot but you can put it into a table format, or even a record format.
-Chad
Unfortunately, i am using Dynatrace managed where I cannot write DQL , so I was playing with the metrics but could not reach to a solution
@Khejazi Managed does not have any built-in metrics related to problems. You cannot create metric on problem data directly in Managed. You can only do that externally by fetching the data using Problem V2 API and sending a metric data. For example, by an ActiveGate extension.
Well,
Can you guide me how to do that if you please
Khejazi
Guide
Still looking for a solution here please
