Dynatrace Managed Q&A
Query Regarding Enabling SSL Pinning and Certificate Rotation in Dynatrace OneAgent SDK
PoojaPandit
Participant
Hi @team,
Could you please help me with a query regarding the Dynatrace OneAgent SDK?
We would like to understand how SSL pinning can be enabled along with SSL certificate rotation in the OneAgent SDK. Specifically:
  • Is SSL pinning handled internally by the OneAgent SDK?
  • If yes, is certificate rotation also supported automatically?
  • If not, what steps are required from the application side to enable these securely?
  • Are there any official documentation links or implementation guidelines available?
Looking forward to your support on this.
Thanks & Regards,
Pooja Pandit
radek_jasinski
Hi @PoojaPandit
In my opinion:
  • SSL pinning is not handled automatically by the OneAgent SDK and must be configured manually using Androi Network Security Configuration or Info.plist on iOS.
  • Certificate rotation is not supported automatically, so pinned certificates must be manually updated in the app.
  • The application must implement platform-specific SSL pinning (network_security_config.xml or DTXPublicKeyPins) and update these settings when certificates change.
Radek
Have a nice day!
