Dynatrace Managed Q&A
What if there's a difference of more than 20 versions for Dynatrace and OneAgent?
If Dynatrace Managed and OneAgent versions difference is older than 20 versions.
What has an effect occurring on Dynatrace or monitoring?
3 REPLIES 3
ChadTurner
DynaMight Legend
DynaMight Legend
From my understanding, Dynatrace only allows you to be 1 year out of compliance when it comes to the oneagent version, after that 1 year, you will be forced to update. If you fall out of compliance, you will not benefit from any new features/releases
-Chad
AntonioSousa
Version 1.169, launched june 6th last year, would probably be the last one supported at the moment.
But in my list, I can only go back to 1.171.
Antonio Sousa
Julius_Loman
DynaMight Legend
DynaMight Legend
It's just Dynatrace might not give you any support if anything goes wrong on that host if OneAgent is older than 1year. Most likely older agents will still work, but it is not guaranteed.
