Why does Dynatrace process group show wrong values
e770144
Newcomer
The application is healthy but the graph related to process group shows dips (see the enclosure) every few hours as if the app is down.  We noticed this kind of trend for several apps.
We are using the following query-
(builtin:pgi.availability:filter(and(or(in("dt.entity.process_group_instance",entitySelector("type("PROCESS_GROUP_INSTANCE"),entityName.contains("na-6y")"))))):splitBy("dt.entity.process_group_instance"))
3 REPLIES 3
p_devulapalli
Leader
How many instances of process you have in this PG?
It could be a issue with a process crashing and restarting intermittently or process becoming unresponsive because of resource constraints on server or few other issue
Do you see anything written in the process logs?
Phani Devulapalli
Peter_Youssef
Leader
Hi @e770144
You can verify the status of the monitored processes under each host and make sure it's not shown as inactive.
Peter_Youssef
Leader
  • in case it's shows "process restart is recommended to get full visibility", proceed with process restart after working hours.
  • this situation is common after oneagent deployments and version updates.
