01 Dec 2024
08:57 PM
20 Dec 2024
10:26 AM
Michal_Gebacki
Advent of Code is an Advent calendar of small programming puzzles for a variety of skill levels that can be solved in any programming language you like. You don't need a computer science background to participate - just a little programming knowledge and some problem solving skills will get you pretty far.
But can you use Dynatrace and DQL for solving those daily puzzles? But why not give it a try!
An example of the day one puzzle solved Dynatrace Security Investigator can be found in Dynatrace Playgorund at https://wkf10640.apps.dynatrace.com/ui/apps/dynatrace.security.investigator/share/d3fb773b-ca97-4e76...
02 Dec 2024 04:08 PM
Day two was quite a puzzle: https://wkf10640.apps.dynatrace.com/ui/apps/dynatrace.security.investigator/share/555f37ef-df3c-4a6f...
03 Dec 2024 09:33 PM - edited 04 Dec 2024 05:28 AM
The solution for the day three puzzle in Dynatrace Security Investigator can be found at: https://wkf10640.apps.dynatrace.com/ui/apps/dynatrace.security.investigator/share/d9fa0636-d1ec-4b9f...
06 Dec 2024 07:22 AM
The part 1 for the 5th day puzzle can be found here: https://wkf10640.apps.dynatrace.com/ui/apps/dynatrace.security.investigator/share/011e835d-d413-4c67...
