17 Sep 2026 10:00 PM
Good afternoon everyone,
I’m looking for some help with a Dynatrace configuration related to environment organization and application-based Segments.
Our goal is to organize our environment by application. We currently have around 4 applications, with multiple servers belonging to each application.
We were advised to follow this approach:
Step 1 – Set the Host Group on existing servers
The servers already have the appropriate Host Groups configured.
Step 2 – Configure Ingest Enrichment
The suggested approach is to create a rule under:
Settings → Collect and capture → Ingest enrichment configuration
For example:
Match: Host Group = APP-ACH-PROD
Map to: primary_tags.application
The idea is that this central mapping would allow current and future servers belonging to that Host Group to inherit the corresponding application tag automatically.
Step 3 – Build Segments using primary_tags.application
The Segments would then be based on the primary_tags values instead of configuring each server individually.
However, I’m having difficulty understanding exactly how Step 2 should be configured, especially the Ingest Enrichment rule and the correct mapping to primary_tags.application.
We have already been working with Support for several days, but we still haven't been able to get a clear example that works for our use case.
Our main objective is to segment the environment by application without having to manually configure every server or run commands individually. With Management Zones, this was much easier for us, so we are trying to achieve a similar centralized organization using the current Grail/Segments approach.
If anyone has already implemented Host Group → Ingest Enrichment → primary_tags.application → Segments, could you please share an example of how you configured the rule?
Even a screenshot or a simple example of the configuration would be extremely helpful.
Thank you very much in advance for any help! 🙏
18 Sep 2026 04:10 AM
Hi @NicoleMT
I have completed the entire setup in my lab environment. Please see the details below:
As you have already created the Host Group, the first step is complete. In my test environment, I created a Host Group named Dev-Linux, and the host is successfully associated with it.
The next step is Ingest Enrichment. Here, you can map the Host Group to a Primary Tag. In my configuration:
This configuration automatically populates the Primary Tag with the Host Group value. The dt.host_group.id attribute resolves to the Host Group name and is mapped to primary_tags.application.
Finally, I configured the Segment using the Primary Tag created by the Ingest Enrichment rule. After the configuration was completed, I was able to see the Dev Linux segment under the Infrastructure & Operations application, and the host associated with the Dev-Linux Host Group was displayed within that segment even other components too like process, containers, logs etc
Now i can see segment under Infrastructure app
Sujit
18 Sep 2026 02:23 PM
Hi @sujit_k_singh,
Thank you very much. I also wanted to ask whether this configuration can be used to filter Services, Traces, Logs, and Dashboards, or if its scope is limited to a specific component.
Aagain.... Thank you very much for your help. It is really useful for us and we truly appreciate your support.
19 Sep 2026 01:19 AM
Hi @NicoleMT
Yes, with this segment configuration, you should be able to see all relevant data.
As shown in the screenshots, the segment can be used to filter and view data across:
You can also validate the data directly from the Segment settings page. Open the segment, click Preview, and verify whether the expected data is visible. If data appears in the preview, it confirms that data is being ingested and matched by the segment configuration.
Services
Tracing
Logs
Segment Setting page
Sujit
