Dynatrace tips
PRO TIP - Business hours in Dynatrace for SLOs or metric events
Julius_Loman
DynaMight Legend
DynaMight Legend
It's quite common you don't provide your services 24x7, but you will run them also during non-business hours. Until business hours or business calendar features land into the Dynatrace product natively, it's possible to have a simple solution.
My approach below works for both Dynatrace Managed and SaaS.
For this feature, we will introduce a new metric - in this example business_hours which will provide just static values:
  • 1 during business hours
  • no value outside of business hours
  • value between 0 and 1 to decrease priorities during "low business hours" (if applicable to your case)
Of course, in your environment you probably have different business hours for different services, thus you will likely need to have a dimension for it, such as level (24x7, 10x5, etc... ). See example below:
For example, values for an 8x5 service level will look like this - a value of 1 between 9:00 and 17:00 for each day and no value outside these times.
Then in the SLO definition, you will simply use metric expression and multiply your desired metric with the business hours metric with the desired dimension representing your business hours, for example - for SLO on key requests:
    builtin:service.keyRequest.successes.server.rate:splitBy():auto
    business_hours:filter(and(or(eq(level,"8x5")))):splitBy():auto
):setUnit(Percent)
You may also commit the :setUnit transformation if you wish.
IMPORTANT: If the metric expression is displayed as a single value (Single value, table, etc) , please include :fold aggregation directly in the expression. This is needed due to the way Dynatrace queries metrics for single value charts. (infinite resolution).
So in the example - during business hours, your original metric will be unaffected (multiplied by 1) and outside of business hours, you will have no value. In this example I've chosen a service level of 8x5, so the result will look like this - notice there are no values during the weekend of 16th and 17th March, and during Monday - Friday we have values only between 8:00 to 16:00 - representing 8x5.
Julius_Loman_1-1715850880208.pngYou can use this approach also in Data Explorer, for Metric event definitions or elsewhere you can utilize metric expressions!
Extension for generating business hours metric
I've decided to publish the extension which allows you to create this business_hours metric based on cron-like schedules or also from a real calendar! (defined in Office 365, Google Calendar or any remote calendar available in ical format).  So you can define your business hours using a shared calendar and the extension will generate the metric accordingly.
You can download the extension from here. You will need to import the CA certificate into your Dynatrace environment and upload the extension. See the README.md for details and links on how to share calendars from Office 365 or Google Calendar.
Using calendar, you can freely define your business hours and exceptions. For example, define 8x5 as a recurring event in your calendar and just delete the occurrences, for example, for holidays.
Changelog
v0.0.16
  • Improved logging
v0.0.15
  • Added support for generating negative levels
  • Extension Dashboard with simple how-to and generated business hours metrics
v0.0.12
  • Initial public version
23 REPLIES 23
henk_stobbe
DynaMight Leader
DynaMight Leader
Hi  Julius,
(you have fans (-;)
I am very interested in your Extension, can you share?
KR Henk
jiri_stefanek
Contributor
Hi Julius,
I am very interested.🙂
Hi @jiri_stefanek ,
can you please reach out to me directly at julius.loman (at) alanata.sk ?
Hi Julius,
I just send you email.
Sent an email to you and looking forward for your reply mate. Thanks
hy
Observer
Hi Julius,
I just sent you an email directly as well. Hope to hear from you soon. Thank you!
hy
Observer
How did you create the custom metric that defines the different business hours for different services, thus you will likely need to have a dimension for it, such as level (24x7, 10x5, etc) in data explorer?
Julius_Loman
DynaMight Legend
DynaMight Legend
@hy  exactly. I've just replied to your email.
elodie_lam
Dynatrace Organizer
Dynatrace Organizer
Hi Julius, this is great! I would also be interested in your extension please 🙂
Thank you!
AurelienGravier
DynaMight Champion
DynaMight Champion
Hi  @Julius_Loman ,
You are so inspiring ! I have created my own python extension to create the custom metric but I use declarative endpoints with a specific format :
However, I'm encountering a limitation when I define a new business opening hours, I have to wait 1 month before use it in my SLO definition otherwise my SLO is null before the custom metric dimension creation.
Did you experiment the same behaviour with your extension ?
Thank you.
Regards Aurelien.
Observability consultant - Dynatrace Associate/Pro/Services certified
I'm not sure if I got your question. The only issue I ever encountered is that you cannot post metrics back in time. So if you define a service level you can only use it for the calculating SLO from current time.so plan accordingly and define your service levels in advance.
That's exactly the limitation I'm encountering : you cannot post metrics back in time.
Thank you for your confirmation.
Yes, that's impossible as metrics can be ingested only one hour back in time. This will likely change soon with Grail, but not for Managed.
rgarzon1
Champion
This could be one of the most clever tricks i seen, thank you for share it @Julius_Loman
fuelled by coffee and curiosity.  searching for a job,
erh_inetum
Champion
Hi Julius,
Thanks a lot for your great post.
I also just sent you and email and like "hy" user I’m interested to know how to create the custom metric that defines the different business hours for different services.
Thanks again.
Elena
germanriezu
Dynatrace Enthusiast
Hi Julius, any ETA for this extension to be in the hub?
@germanriezu unfortunately it was not accepted. Only Dynatrace signed extensions can be in the HUB as of today, no 3rd party extensions. So at least for upcoming months this will stay as it is. You can download it from the provided link including the certificate and use it as a 3rd party extension. In case of any issues, reach out back here in this thread.
Kumari_Sapna
Hi @Julius_Loman Thank you for sharing the detailed explanation.
But the link shared above to download the extension is not accessible Are there some restrictions or any other issues? Can you kindly confirm?
Thanks in advance
@Kumari_Sapna, apparently there have been some changes to the sharing policy where this was hosted. I moved this project to github. The link was updated. Thanks for reporting.
JAR1
Guide
Hi @Julius_Loman .
We have version 0.0.12 on one client and we have a few questions:
Is version 0.0.17 added support for python 3.14?
Is there any documentation that outlines the steps to update it?
Julius_Loman
DynaMight Legend
DynaMight Legend
Hi @JAR1 ,
yes, version 0.0.17 was updated with latest extension SDK and works with Python 3.14. (ActiveGate 1.333+).
Thank you so much for your help, @Julius_Loman !
I have a question about updating the extension: we have the initial version installed and working fine. When it was installed, a self-signed certificate was generated and uploaded to the AG.
The question is, when updating now, do I need to generate a new certificate and upload a .pem file to the AG? Or can I upload the new code?
Thanks again
BR
JAR
If you have built on your own, you can reuse the certificates you have. However, you can use the built version that is in the releases, but you must upload the certificate that provided in the release to your environment and the active gate.
