18 May 2022 06:41 AM
Hello all,
I want to apply automatic tags on containers in Dynatrace, but when I'm trying to create a new tag, I don't see any option to apply the tags to "containers" type (see attached image).
Do you maybe have an idea for this? Am I missing something?
Thank you all in advance.
18 May 2022 09:47 AM
@YuvalKonstanti Did you try to use EntitySelector on the same page.
18 May 2022 12:08 PM
You can check below article for open shift, and based on your kn8s orchestration engine can follow similar way to configure tags.
Automatically apply tags to monitored OpenShift processes | Dynatrace news
18 May 2022 12:28 PM
@techean Thanks for sharing the article.
@YuvalKonstanti what is deployment method are you using, Dynatrace operator, cloud-native full-stack injection etc... as almost all processes are injecting important tags automatically.
