Dynatrace tips
Tip: How Certificate Check Intervals Influence SSL/TLS Problem Detection & Resolution in Dynatrace
AravindhanV
Advisor
Understanding how Dynatrace handles SSL/TLS certificate checks is essential for accurately interpreting problem lifecycles, especially when issues seem to remain open longer than expected or reappear after process restarts. Below is a clear explanation that helps clarify why this happens.
📌What the Certificate Check Interval Actually Controls
The certificate check interval determines how often Dynatrace performs certificate discovery and metadata updates and how certificate‑related problems are opened and closed.
When Dynatrace identifies an expired or soon‑to‑expire certificate, the problem stays open until the next scheduled check confirms the issue is resolved. Even if the certificate is renewed immediately, Dynatrace will not close the problem instantly—it waits for the next interval to validate the updated certificate.
Example
If the check interval is 24 hours, any certificate problem will remain open for at least 24 hours.
  • Long intervals → problems stay open longer
  • Short intervals → quicker validation and closure
🔄How Process Restarts Affect Certificate Problems
Dynatrace ties certificate problems to the specific process instance (process ID) from which the certificate was discovered.
This means if the monitored process is:
  • Restarted
  • Terminated
  • Crashed
…before the next certificate check runs, Dynatrace will automatically close the existing problem, because the original process no longer exists in the environment.
What Happens Next?
During the next certificate check interval:
  • Dynatrace re‑evaluates the certificate
  • If the issue still exists, a new problem is created
  • This is common when certificates are discovered from short‑lived or frequently restarting processes
Even though the custom device linked to the certificate stays the same, each process restart creates a new process ID. Dynatrace treats this as a new monitored entity, resulting in:
  1. Old problem closed with the old process
  2. New problem opened when the certificate issue is detected again
📝Summary
Dynatrace’s problem lifecycle for certificate issues depends on two key factors:
1. Certificate Check Interval
  • Determines how often Dynatrace validates certificates
  • Controls how long certificate problems remain open
  • Influences how quickly problems close after renewal
2. Process Instance Status
  • Certificate problems are tied to the specific process ID
  • Restarts or crashes automatically close existing problems
  • New problems may appear during the next check if the issue persists
#SSLCertificates #ProblemDetection #ProcessMonitoring
Happy Dynatracing!!!
aravind
0 REPLIES 0
