08 Dec 2024
02:02 AM
01 Apr 2025
10:53 AM
Hi Team,
We have deployed Environment AG in our environment used for " Routing Traffic / Extensions". Just realised that our extension has no data while the devices are up and running. A deeper insight shows below:
1. Active Gate - Offline for 2 days
a. Does this affect our observability in PROD ? As we see no alerts on AG in our Problems Dashboard and can see data captured as expected - IS it because OA has taken a direct connectivity route than via AG as offline ?
2. We are using SNMP CISCO Generic Extensions in our environment. Our Client has showcased that connectivity from Target devices to AG is working fine. But in out extension page we see "Inactive For 2days"
Please advise. Thanks for your time.
08 Dec 2024 08:15 AM
Hi @Kani
Regarding the highlighted concerns as simple as that:
Dynatrace resources:
Hoping it helps.
BR,
Peter
08 Dec 2024 08:24 AM
Hello @Kani
Resources:
Hoping it adds value.
KR,
Peter
08 Dec 2024 10:28 PM
Hey Kani,
To answer the first question about losing observability, it should not affect anything as long as all other monitoring components are allowed to directly connect to Dynatrace SaaS and the Activegate was not running any cloud integrations or other extensions.
Also for the second point, the extension will be inactive if the Activegate is offline so there is nothing to troubleshoot there until the Activegate is running again.
As for troubleshooting the Activegate, if it is possible try running Activegate diagnostics as specified here. I suspect you won't be able to do that though as you say it's offline at the moment, so the next thing is to try and investigate why it stopped. Information on where to find the logs can be found here. While investigating you can also try restarting the Activegate as mentioned in the docs here.
Also, for the future once you have things running again you can monitor the Activegate from within Dynatrace in a couple of ways to make it easier to troubleshoot if it goes down again.
Hope the above helps!
