28 Feb 2023
09:46 PM
20 Aug 2024
11:48 AM
Michal_Gebacki
Hi all,
upon investigation, I have found that the latest version of ActiveGate (1.259.307) is causing problems with extensions that utilize multiple Python objects. One of the extensions impacted is the SSL certificate expiry check extension, which is an external extension that provides much more detailed information than the supported extension. Given the usefulness of this extension, would it be possible to convert it into an official extension?
https://github.com/mediro-ict/activegate_python_ssl_plugin/releases
28 Feb 2023 10:32 PM
Hi, that extension is built and is supported by a partner so we cannot make it into an official extension. Please reach out to the partner via the issues section of the GitHub repo so they can look at it.
Mike
