02 Jun 2022
02:07 PM
03 Jun 2022
08:58 AM
Hi team,
Just asking a very old question, did any one tested any type of custom integrations for ingesting server infra metrics running SOLARIS OS on legacy systems?
03 Jun 2022 08:48 AM
There is a plugin from the extension team to gather solaris metrics.
07 Jun 2022 03:33 PM
we are going to test it at one of our clients environment, will be posting a feedback on metrics being captured
04 Jun 2022 05:02 PM
Hello @richard_guerra & @pahofmann
Were you satisfied/or got the desired results with the SUN Solaris OS metrics using this extension?
Babar
06 Jun 2022 03:39 PM
Hello Babar,
Sorry, I haven't used this extension. Our Solaris hosts all have the Java hence we're using the Java OneAgent.
07 Jun 2022 03:40 PM
We are also using OneAgent to monitor the Apache/Java/WebSphere etc. I was curious to know the benefits of using this extension on top of the existing PaaS monitoring.
Babar
24 Feb 2023 02:04 PM
On a Solaris machine, the generic Unix one produces a Total CPU_Used% metric and FreeSpace% per Disk.
Im not finding any Total Memory_Used% metric, on any setting (Solaris, generic, HP, ...) or any version (for RHEL 7 or 8).
So only a couple of key Infra metrics work.
24 Feb 2023 04:07 PM
You should always use the most applicable OS as that is what determines which commands are executed and what the expected command output is. A common cause for missing metrics is the relevant commands not being found/on the path.
If you haven't, check the troubleshooting guide: https://www.dynatrace.com/hub/detail/remote-linux-monitoring/#troubleshooting
The other possibility is something is unexpected in the output of some commands and that would need to be identified and handled. A support case is best in these situations so that the output can be communicated.
The logs should tell pretty clearly which scenario it is.
03 Jun 2022 08:02 PM
@richard_guerra @pahofmann Thankyou both for the help, I knew this might already exist however didn't searched for it as I was unable to find similar question in the open community. Just though we post this type of question where users might be searching any thread for 😉
