Extensions
Custom ext for oracle DB 11
manok
Visitor
Hi
I have created the Oracle DB 11 custom ext in our environment and added the customer DB server, post that, am able to see the DB instance in database overview, however, unable to see the host ip address. the relationship i already added. please advise. i raised a case with support team. they said it is out of scope.
t_pawlak
DynaMight Leader
DynaMight Leader
I believe the issue is related to topology mapping rather than Oracle monitoring itself.
I would check the following:
  • Is the Oracle server monitored by OneAgent? If not, Dynatrace has no host entity to correlate the database with.
  • Does the extension create a relationship to the Host entity rather than only to a custom entity?
  • Does the entity ID used in the relationship match the actual Dynatrace Host entity ID?
  • If the IP address is collected only as a custom property, it may be visible in the entity properties but will not appear in the standard Database Overview host/IP field.
If the relationship is already configured correctly and the host is still not displayed, I'd recommend reviewing the extension's topology mapping, as that's what determines how the database entity is linked to the monitored host.
