Extensions
Connection Pool Monitoring on Services running in Kubernetes Pods
Vamsikrish
Newcomer
Hello All,
i am trying to use Tomcat JMX extension to monitor connection pools.
I have added the host name in which Kubernetes pods are running . After configuring the status is still PENDING , and no logs to check what is the issue .
AntonPineiro
Can you check OneAgent extensions logs?
Best regards
