11 Jun 2020 10:47 AM
Hi Everyone,
I'm writing a custom pluggin allowing me to monitor the host units used by my tenant. The pluggin works well on the simulator, the custom metrics is displayed in the custom chart window but there is no data in the chart. Does someone know where the problem can be ?
Here are the code of the plugin and the json, considering the token ID and env ID are well informed :
from requests import get as rg import json from ruxit.api.base_plugin import BasePlugin from ruxit.api.snapshot import pgi_name # Calculate the licence number for a given environement def calcHostUnits(envID, token): #initialize values hostUnits = 0 dynatraceBaseUrl = "https://XXXXXXXXXXXXX/e/" + envID + "/api/v1/entity/infrastructure/hosts" headers = { "api-token": token } #API call response = rg(dynatraceBaseUrl, params = headers) response = response.json() #If response not empty, get consumedHostUnits for each host if len(response) != 0: for entry in response: hostUnits += entry['consumedHostUnits'] return hostUnits class DemoPlugin(BasePlugin): def query(self, **kwargs): hostUnits = 0 token = self.config["Token"] ID = self.config["EnvID"] hostUnits = calcHostUnits(ID, token) print("On consomme ", hostUnits) self.results_builder.absolute(key='hostUnits', value=hostUnits){ "name": "custom.python.totalhostunits", "version": "0.3", "type": "python", "entity": "HOST", "metricGroup": "My_Metrics.plugins", "favicon": "./favicon.jpg", "source": { "package": "demo_plugin", "className": "DemoPlugin", "install_requires": [ "requests>=2.6.0" ], "activation": "Singleton" }, "metrics": [ { "timeseries": { "key": "hostUnits", "unit": "PerMinute", "displayname": "Host Units consumed" } } ], "configUI": { "displayName": "API calls configuration", "properties": [ { "key": "Token", "displayName": "Token", "displayHint": "Use a Token authorized on this tenant" }, { "key": "EnvID", "displayName": "Environment ID", "displayHint": "Enter yout environment ID, can be find in the URL" } ] }, "ui": { "charts":[{ "group": "Dynatrace Informations", "title": "Host Unit Consumption", "series":[{ "key": "hostUnits", "aggregation": "SUM", "displayname": "Host Units consumed", "seriestype": "line" }] }], "keymetrics": [ { "key": "hostUnits", "aggregation": "count", "mergeaggregation": "avg", "displayname": "Host Unit Counter" } ], "keycharts": [ { "group": "Dynatrace Informations", "title": "Host Unit Consumption", "series": [ { "key": "hostUnits", "aggregation": "SUM", "displayname": "Host Units consumed", "seriestype": "line" } ] } ] }, "properties": [ { "key": "Token", "type": "String", "default_value": "XXXXXXXXXXXXX" }, { "key": "EnvID", "type": "String", "default_value": "XXXXXXXXX" } ] }
11 Jun 2020 11:08 AM
I think that an ActiveGate plugin makes more sense for the use case. If you want to do it as a host plugin I'd go with something like this as the last line of your Python script:
self.results_builder.add_absolute_result(PluginMeasurement(key="hostUnits", value=hostUnits, entity_selector=HostSelector()))
I'm not sure it's required, but my host extensions always have this line in them as well in the root of the plugin.json:
"processTypes": [0],
05 Apr 2022 10:17 AM
Hi together,
We encounter a similar issue. We have quite a simple extension. Currently it would only generate some mock data.
The Python code:
import random
from ruxit.api.data import PluginMeasurement
from ruxit.api.selectors import HostSelector
logger = logging.getLogger(__name__)
class Ports(BasePlugin):
logger.info("Activation context: %s", self.get_activation_context)
# create some random mock data
used_ports=random.randrange(10)
free_ports=random.randrange(10)
total_port_range=used_ports+free_ports
# write results
self.results_builder.add_absolute_result(PluginMeasurement(key='used_ports', value=used_ports, entity_selector=HostSelector()))
self.results_builder.add_relative_result(PluginMeasurement(key='free_ports', value=free_ports, entity_selector=HostSelector()))
self.results_builder.add_relative_result(PluginMeasurement(key='total_port_range', value=total_port_range, entity_selector=HostSelector()))
And the plugin.json looks like this:
"name": "custom.python.ports",
"version": "0.0.19",
"type": "python",
"entity": "HOST",
"technologies": [ "PYTHON" ],
"metricGroup": "custom.python.ports",
"source": {
"package": "ports",
"className": "Ports",
"install_requires": [],
"metrics": [
"timeseries": {
"key": "used_ports",
"unit": "Count",
"displayname": "Used ports"
"timeseries": {
"key": "free_ports",
"unit": "Count",
"displayname": "Free ports"
"timeseries": {
"key": "total_port_range",
"unit": "Count",
"displayname": "Total port range"
"configUI": {
"displayName": "OneAgent Ports extension"
}However, we do not get any data in Dynatrace.
05 Apr 2022 10:35 AM
Can you remove this line from your plugin.json and try again? Do you see anything in the plugin log file on the OA where you placed the files?
05 Apr 2022 11:06 AM
Hi Mike!
Yes it looks like this does the trick!
Thank you and kind regards,
Patrick
05 Apr 2022 12:43 PM
Hi Mike,
I have a follow-up question. The documentation states the following:
processTypes | Integer Array | Type of process that plugin monitors, as defined in the ID column of the known process types table. This serves as an alternative to processTypeNames. The method is kept for compatibility, we recommend to use improved “technologies” instead. |
Kind Regards,
Patrick
05 Apr 2022 12:45 PM
It doesn't work because you're not monitoring a Python process, you're monitoring the whole host.
05 Apr 2022 01:06 PM
Ok, I understand. Is there another way to do it?
05 Apr 2022 01:57 PM
Yes, by removing it like you did. That worked, right?
05 Apr 2022 02:16 PM
Yes, it works. However, I was just wondering if this is the right way to do it. Thank you!
05 Apr 2022 04:08 PM
My team did 350 or so extensions and that method is used by several of them. If it works it works 🙂
