Dear All,
We have a custom installation of the Environment ActiveGate with the below folders:
The remote plugin module is available in the following locations:
In this situation, what is the right location to place the ActiveGate extension e.g. custom.remote.python.ibmmqpcf?
I used the below location and it worked for me.
Babar
Correct place to add custom extension is in install path.
You shouldn't have two plugin_deployment folders. Was the one in config path added manually?
Hello @Maciej G.
Thank you for the confirmation.
Yes. I will not disclose but someone from the chat support suggested me earlier when I was going through with troubleshooting 🙂
Babar
