11 Jul 2024
08:40 PM
12 Jul 2024
02:59 PM
I have developed a Python extension using the 2.0 framework that connects to a Microsoft SQL Server, executes a stored procedure, and reports custom metrics to Dynatrace. I want to link my custom metrics to a host that is different from the one added automatically by the OneAgent, because the host the extension is running on is not necessarily the one that should be associated with the metrics.
I am trying to define a RUNS_ON relationship from custom entities to a sql_server_instance entity. In my extension.yaml file I have the following:
version: 0.0.14
minDynatraceVersion: "1.253"
author:
python:
runtime:
module: foo_extension
version:
min: "3.9"
activation:
remote:
path: activationSchema.json
local:
featureSets:
- featureSet: Job
metrics:
- key: mssql.job.status
- featureSet: Job Step
metrics:
- key: mssql.jobstep.status
metrics:
metadata:
description: last run outcome of the job
displayName: mssql job status
unit: gauge
dimensions:
- key: job_id
displayName: Job ID
- key: job_name
displayName: Job Name
- key: category
displayName: Category
- key: type
displayName: Type
- key: owner
displayName: Owner
- key: current_execution_status
displayName: Current Execution Status
- key: has_step
displayName: Total Number of Steps Per Job
- key: current_execution_step
displayName: Current Execution Step's Name
- key: step_id
displayName: This Step's ID
metadata:
description: last run outcome of the job step
displayName: mssql job step status
unit: gauge
dimensions:
- key: job_id
displayName: This Job's ID
- key: job_name
displayName: This Job's Name
- key: step_id
- key: step_name
displayName: Step Name
topology:
types:
- name: sql:sql_server_instance
displayName: MSSQLSERVER
enabled: true
rules:
- idPattern: sql_server_instance_{originating_server}
instanceNamePattern: "MSSQLSERVER on {originating_server} (via: {originating_server})"
iconPattern: mssql
sources:
- sourceType: Metrics
condition: $prefix(mssql.job.)
condition: $prefix(mssql.jobstep.)
- name: foo-extension:job
displayName: Job
enabled: true
rules:
- idPattern: "{job_id}"
instanceNamePattern: "{job_name}"
iconPattern: mssql
attributes:
- key: type
displayName: Type
pattern: "{type}"
- key: owner
displayName: Owner
pattern: "{owner}"
- key: category
pattern: "{category}"
sources:
role: default
- name: foo-extension:jobstep
displayName: Job Step
enabled: true
rules:
- idPattern: "{job_id}-{step_id}"
instanceNamePattern: "{step_name}"
iconPattern: mssql
attributes:
- key: job_id
displayName: this job's id
pattern: "{job_id}"
- key: job
displayName: this job's name
pattern: "{job_name}"
- key: step_id
displayName: this step's id
pattern: "{step_id}"
sources:
role: default
relationships:
- enabled: true
sources:
fromType: foo-extension:jobstep
typeOfRelation: CHILD_OF
toType: foo-extension:job
- enabled: true
sources:
- sourceType: Entities
mappingRules:
- sourceProperty: originating_server
sourceTransformation: To lower case
destinationProperty: server
destinationTransformation: To lower case
typeOfRelation: RUNS_ON
toType: sql:sql_server_instance
- enabled: true
sources:
mappingRules:
(The originating server dimension is specified for both of my custom metrics (although it is not mentionned in the metrics section), and its value is the name of a host already present on Dynatrace.)
With this code, the CHILD_OF relationship is working properly, but when I look at the runs_on field of my custom entities on Dynatrace I see "null" for all of them.
I have previously been able to specify the dt.entity.host dimension by assigning its value to a host's id I found in Dynatrace, but I have never gotten the relationship to work.
What else could I try to get my topology working in Dynatrace? Is my mapping done correctly and is this the right relationship type? Is there something else missing in my topology?
Any help on the matter is greatly appreciated!
16 Jul 2024 07:21 PM
I ended up using a child_of relationship instead. I also realized that the sql:sql_server_instance entity should not be defined in my code since its already present in Dynatrace. This created a second entity with the same name as the one in Dynatrace and caused issues with mapping. Here is what worked for me:
metrics:
metadata:
unit: gauge
dimensions:
- key: job_id
displayName: Job ID
- key: job_name
- key: category
- key: type
displayName: Type
- key: owner
displayName: Owner
- key: has_step
- key: step_id
- key: originating_server
displayName: Originating Server
metadata:
unit: gauge
dimensions:
- key: job_id
- key: job_name
- key: step_id
- key: step_name
topology:
types:
displayName: Job
enabled: true
rules:
- idPattern: mssql_job_{job_id}
iconPattern: mssql
attributes:
- key: type
displayName: Type
pattern: "{type}"
- key: owner
displayName: Owner
pattern: "{owner}"
- key: category
displayName: originating_server
pattern: "{originating_server}"
sources:
role: default
enabled: true
rules:
- idPattern: mssql_job_{job_id}_{step_id}
iconPattern: mssql
attributes:
- key: job_id
pattern: "{job_id}"
- key: job
- key: step_id
sources:
role: default
relationships:
- enabled: true
sources:
- enabled: true
sources:
mappingRules:
