14 Jan 2019
02:07 PM
28 Jun 2021
01:36 PM
Hi All,
Is there a Generic execution plugin available for Dynatrace managed. I know you can create your own custom plugins but wanted to know if there is anyone who has already created such plugin.
Amarpreet
14 Jan 2019 02:23 PM
You mean some plugin that can be starter point to create your own? Dynatrace has provided such sources:
https://dynatrace.github.io/plugin-sdk/plugins/ind...
14 Jan 2019 03:17 PM
Actually simialr to Appmon "Generic Execution Plugin" I wanted to know if there is one for Dynatrace managed.
14 Jan 2019 04:38 PM
Ok I remember what this plugin does. Actually there is no such plugin because it wont work. If you want push some metrics to dynatrace you can write custom piece of code that will do it for you over API. If you want execute something as a result of problem rising, you have to create piece of code that will serve HTTP service. Then from Dynatrace => Custom integration you can send json payload via POST to this WebService. Then you can handle this event to execute some command on monitored host. You will not make it in any other way I think.
