Extensions
How to configure Filesystem monitoring extension for Azure Blob File Age and File Count?
tdavison76
Participant
New to Dynatrace and the is my first post in the Community,  I see that the Filesystem monitoring supports Azure Blob Storage monitoring, but am having a hard time figuring out how to configure the extension for this.  The documentation only says that
Azure Blob storage is supported.
When selected, two new fields will appear: the Azure account and the key.
Make sure OneAgent has network connectivity to Azure.
But, I don't see anywhere in the configuration that I can select Azure or enter in the Account Details and Container Name.
Anyone familiar with how to achieve this by any chance?
Thanks for your help,
Tom
DanielS
Hello @tdavison76 under File System you can select Azure file share and complete the details. See image attached.
