30 Jan 2025
02:10 PM
10 Feb 2025
10:23 AM
31 Jan 2025 09:51 PM
It is normal behavior and expected. The /ui/entity/PROCESS_GROUP_INSTANCE page is the Unified Analysis page which is where we can define charts etc... for generic topology entities in 2.0 extensions. There is no way to affect or display data on that 'classic' process group instance page, that was only possible through 1.0 extensions.
Our Dynatrace-built/supported extensions work the same way. We often include a note about this on how to get to this screen on the Hub pages e.g. Redis via the Metrics and events drill down. The fact that the 'classic' process group instance page is the default still does complicate this but there is no way around it.
03 Feb 2025 07:01 AM
Thanks @JamesKitson for the answer. At least I know how to navigate to the Unified Analysis page, which I prefer over the classic one. Do you know if it will become the default navigation from HOST?
03 Feb 2025 07:54 PM
This isn't an area where I am involved, but I don't believe so. As of now I have heard that all the screens/layouts/paths in these 'classic' views will stay as-is.
