Extensions
IBM MQ extension (remote) for an MQ running on IBM i Series
jose_araya
Advisor
Hello community!
I have a question about this extension:
https://www.dynatrace.com/hub/detail/ibm-mq/?query=IBM+MQ&filter=all
Does it work for a IBM MQ installed on IBM i Series platform?
As you can see IBM i supports MQ as well, not only AIX, Linux and Windows.
We know Dynatrace doesn't have OneAgent for IBM i, so we can't work with the Local version of the extension.
Has anyone configured the remote extension under these circumstances?
JD.
5 REPLIES 5
Mike_L
Dynatrace Guru
Dynatrace Guru
We have customers running the ActiveGate version of the IBM MQ extension against IBM MQ installed on IBM i. We don't officially support it though, so if you run into trouble it'd just be best effort support.
Mike
You have Mike? Excellent!
Can you tell me if there is any specific user permissions requirement or special configuration different to an MQ installed on other platforms?
Anything relevant could help us a lot!
Thank you very much.
Hi Jose,
We don't have specific user permissions for IBM i since it is unknown to us. Just make sure to use the IBM i equivalent permissions you have on the IBM MQ ActiveGate extension page.
Diego
Understood.
So right now what I would like the most is to get a real confirmation on this support because this may impact our migration path for the MQ installed on IBM i Series.
If this is really supported then it is worth it for us to migrate, but this would require an effort because we currently have version MQ 7.0.1 running on those i Series.
Jose.
Confirmed, no official support.
But we don't support IBM MQ 7.x either. IBM stopped support to 7.0 in 2015. I don't think even some of those metrics are available in those older versions and may give you errors. Authentication back then was very different too so I'm almost certain you will encounter issues with that as well.
It is best if you upgrade your environments to supported versions of IBM MQ.
Diego
