10 Aug 2023
11:08 PM
11 Aug 2023
08:32 AM
I'm using the Fastlane plugin to upload our dsyms to Dynatrace. I've started receiving this error:
INFO [2023-08-01 19:30:42.49]: ▸ 2023-08-01 19:30:42.493 DTXDssClient[26630:90673] WARNING Extract [DTXSymbolExtractor.mm:916-259] Demangled symbol name of length 6842 exceeds maximum length of 5000. The symbol will be truncated and not be included in full length. This behavior can be overridden by using the maxSymbolSize parameter.
Looking at the documentation (https://github.com/Dynatrace/fastlane-plugin-dynatrace), I don't see `maxSymbolSize` as an available parameter to provide:
From the log file, I see that we're using:
DTXDssClient version 8.271.2.1007 built on 2023-07-14
But the logs also show it was updated:
INFO [2023-08-01 19:30:02.11]: Found a different remote DTXDssClient client. Removing local version and updating.
I started digging into this after checking a crash, and seeing a message "The stack trace could not be processed correctly with the uploaded mapping file."
Any suggestions?
Jamie
11 Aug 2023 06:40 AM
Hi!
maxSymbolSize Limits the maximum length (characters) of the demangled symbols. Can be disabled by setting it to 0. (Default 5000)
11 Jun 2025 01:09 PM
Hi @Patrick_H,
I am getting the same issue. Does the fastlane plugin give the possibility to set the maxSymbolSize to 0 ? didn't find a way to do it
Available parameters are only the following :
Key Description default value
| action | (iOS/tvOS only) Action to be performed by DTXDssClient (upload or decode). | upload |
| username | (iOS/tvOS only) The username/AppleID to use to download the dSYMs. Alternatively you can specify this in your AppFile as apple_id. | |
| os | The type of the symbol files, either ios, tvOS or android. | |
| apitoken | Dynatrace API token with mobile symbolication permissions. | |
| appID | The application ID you get from your Dynatrace environment. | |
| bundleId | The CFBundlebundleId (iOS, tvOS) / package (Android) of the application. Alternatively you can specify this in your AppFile as app_identifier. | |
| versionStr | The CFBundleShortVersionString (iOS, tvOS) / versionName (Android) | |
| version | The CFBundleVersion (iOS, tvOS) / versionCode (Android). Is also used for the dSYM download. | |
| symbolsfile | Path to the dSYM or Android mapping file to be processed. (Android only): If the file exceeds 10MiB and doesn't end with *.zip it's zipped before uploading. This can be disabled by setting symbolsfileAutoZip to false. | |
| symbolsfileAutoZip | (Android only) Automatically zip symbolsfile if it exceeds 10MiB and doesn't already end with *.zip. | true |
| server | The API endpoint for the Dynatrace environment (e.g. https://{environmentid}.live.dynatrace.com or https://dynatrace-managed.com/e/environmentID). | |
| cleanBuildArtifacts | Clean build artifacts after processing. | false |
| tempdir | (OPTIONAL) Custom temporary directory for the DTXDssClient. The plugin does not take care of cleaning this directory. | |
| debugMode | (OPTIONAL) Enable debug logging. | false |
| customLLDBFrameworkPath | (iOS/tvOS only) (OPTIONAL) Custom path to the LLDB framework used as runtime dependency by DTXDssClient (e.g. /Users/test/Documents/LLDB.framework). | |
| autoSymlinkLLDB | (iOS/tvOS only) (OPTIONAL) Automatically find and create a symlink to the LLDB framework into the DTXDssClient's temporary folder. | true |
Thanks for your help
12 Jun 2025 09:00 AM - edited 12 Jun 2025 09:54 AM
Hi @jbaf!
we checked our plugin and that option is currently not there - we will add it to the next release.
Update: truncated symbol names are not really an issue - this just shortens autogenerated symbol names that would not really help on analyzing a crash report (a method call with a 5k char long name?). If your issue is that you got "The stack trace could not be processed correctly with the uploaded mapping file.", then this should not be related to the truncation - more likely to a symbol file uploaded not matching the app build it was uploaded for (has to be exactly from that one build that was published, not just from same repo checkout state).
11 Aug 2025 09:01 AM
The missing maxSymbolSize parameter is now available in the latest release: https://github.com/Dynatrace/fastlane-plugin-dynatrace/releases/tag/v2.1.5
07 May 2024 09:29 AM
For the last point of the solution, did you create a support ticket and what was the solution? We also receive the following message for stack traces:
- The stack trace could not be processed correctly with the uploaded mapping file.
Could you please also specify in which log files you found the error messages (path to the logs)?
Many Thanks,
Urs
