Extensions
JMX Connection Pool - Does it work in Cloud ?
susmita_k
Organizer
We are migrating one of our java application in Kubernetes cluster. Can we still configure the JMX Extension and get the connection pool details ? We have tried to configure the same, but it is not successful.
Julius_Loman
DynaMight Legend
DynaMight Legend
Yes as long as the agent is injected and Java jmx support is enabled, it will work. JMX is monitored from the OneAgent code module.
If you are worried about some errors, it can happen if the mbeans are not present in the process. For example JBoss Connection pool has two types of connections and typically only one is configured.
