Extensions
NetApp OnTap (Remote) Extension luns in down state not monitored
almog42
Frequent Guest
heyy
i came upon a bug in the netapp extension that when a lun is offline he does not appear to be in Dynatrace the reason for it is because when a lun is offline netapp api does not return a "used" field in the lun status json
which breaks the lun metric reports (which the lun object creation relys on)
the bug consisted for a couple of extention versions (noticed at version: 2.6.3)
the fix is pretty simple an if in the LUNSpace Class in ontap_api
and another if and try switch at the function report_lun_metrics in main
how do i report the bug to Dynatrace ? i don't want to manually patch every new version of the extension to be up to date
thanks in advence
Mike_L
Dynatrace Guru
Dynatrace Guru
You can raise it as a regular support ticket here: https://support.dynatrace.com/
Mike
