Oneagent executing a simple Python script.
alex_cunha
Newcomer
Hey guys!
I would like to know if it is possible for oneagent to run a simple python script on the host on which it is installed with the given time, for example, every 1 minute? If it is possible, where in your configuration can I inform the script location and execution interval time?
Thank you very much gentlemen!
AntonioSousa
You can do what you want with OneAgent extension. Please take a look at:
https://www.dynatrace.com/support/help/extend-dynatrace/extensions
Antonio Sousa
alex_cunha
Newcomer
Thanks Antonio,
I´m looking for simple example, but thanks for link the documentation.
Alex
