06 May 2025 02:48 AM - edited 06 May 2025 04:01 AM
There are no ActiveGates in this group capable of executing the extension. The extension won't work until at least one ActiveGate fulfills the requirements.
Above is the error. It was successful before but now that is the error. Already restarted the service as well. How to address the error?
06 May 2025 07:07 AM
hi @AbbieA, Can you please check your existing AG which was connected earlier, there might be 2 possible reasons
Would recommend to login the AG server and check the process and the Logs.
06 May 2025 07:16 AM
Hi @AravindhanV, thanks for the response. I'm not yet familiar on the AG logs, what is the path of the logs in AG (windows) to check this?
06 May 2025 07:21 AM
@AbbieA, You can get the logs from the below location %PROGRAMDATA%\dynatrace\gateway\log
ActiveGate directories — Dynatrace Docs - This might be helpful for you too.
13 May 2025 12:39 AM
Hi. After restarting the EEC, what specific log filename to check?
13 May 2025 09:48 AM
Hi @AbbieA
What is the current version of your AG, I believe you are using older version of AG that uses python 3.8 while using the latest version of the extension. You have to update the AG version to the latest or to downgrade the extension version.
Islam
15 May 2025 02:21 AM
Hi @Islam_Zedan , the current version of our AG is 1.311.
15 May 2025 04:13 AM
This is resolved. The port was reverted to the default value. We just updated the conf file to update the port we are currently using.
