Extensions
Running v2 extension on a certain ActiveGate inside a group?
AntonioSousa
For scalability reasons, I have ActiveGate groups with more than one ActiveGate.
Now, I have several EF2 extensions running on those groups, and it works well.
But, now I need to have a particular EF2 extension running on a specific ActiveGate, for several reasons.
It would be great to have an ActiveGate belong to several groups, but that is not possible. I also cannot change the group because that would break the other extensions.
In EF1, I just had to install it in the ActiveGate I wanted...
What would be the best way to achieve this with EF2? Using fastcheck?
Antonio Sousa
3 REPLIES 3
Mike_L
Dynatrace Guru
Dynatrace Guru
Using fastcheck would indeed be the way to solve this. I’d go with checking for the existence of a specific file for example if I were you, that way you don’t have to hardcode the AG name into the extension.
Mike
@Mike_L,
Never had used fastcheck before, and it seems to work well. I do believe though that we need an AG to eventually belong to more than one group: https://community.dynatrace.com/t5/Product-ideas/Activegate-belonging-to-several-groups/idi-p/259362
Interestingly, I discovered that it only runs the first time. It I update a monitoring configuration, it doesn't run again. But I can live with that 😁
So, when what cases does fastcheck run again? When restarting the extensions module? In any other cases?
Antonio Sousa
Whenever the cluster needs to re-validate what AG will execute the extension, so during communication loss and when you go over the hard usage limit.
Mike
