Open Q&A
Can dynatrace possible to capture two pattern using regex ?
andra_nosa
Helper
i have create request attribute to capture some parameters but i want to capture just 2 values on that, can dyntrace possible?
if i see there is regex on optional menu, please help...
this parameter example :
{ERROR_CODE=ESB-51-000,
RESPONSE_REF_NO=20200923100001028261,
ERROR_MESSAGE=Success,
RESPONSE_REASON=SUCCESS,
RESPONSE_CODE=00}
i want to get ERRCODE and ERRMSG
RG,
ChadTurner
DynaMight Legend
DynaMight Legend
Why not create two request attributes? This way you will have the granularity to isolate down to one and or both attributes.
-Chad
You can also leverage using the " | " to allow two variables with the regex detection
-Chad
