Open Q&A
Classic Tags (Manual/Automatic) vs Primary Tags (Grail based tagging)
david_manes
Frequent Guest
Hey guys,
I wanted to get thoughts on this. Within my company we use tagging heavily for not just filtering, but for escalation.
The process is basically like this "Tagged Resource goes down --> Problem opened --> Problem sent to Moogsoft with meta data (process name, tags, issue, etc) --> Moogsoft investigates the tags --> Based on the tags, it will either ignore, create a ticket, or escalate to NOC and create a ticket".
We also using tagging in other ways, but above is the primary way. Now, we found out that automatic tagging will no longer exist with the Grail backend and will only be tied to classic entities, thus we won't be able to create segments, use the Smartscapes 2.0 app properly, use some DQL commands that would do advanced filtering based on autotags, etc.
The "new" method is going primary tags, which are basically tags that are applied at source (at the app level). Although this sounds good on paper, as I am sure that is where the decision was made without real world feedback, this presents a problem for us. Within my company, we do not only have one Development team and one Operations team, under one VP, with one Director. We have a hundred different development teams with 100 different VP's, Operations teams with different VP's/Directors, etc. The Development and Operations teams are already extremely overwhelmed with the amount of work they have going on, which makes the Monitoring team less of a priority (defining tags), than their priority to build/update the applications.
Then we also throw in items that do not have OneAgent installed (Items added through extensions, such as NTWK devices). We cannot define tags at source and even if we could, I highly doubt the NTWK team cares enough to let us tell them to do it.
To add alittle more to this. Even though standards are set, we also noticed in our Azure environment that some tags are are follows: "SupportTeam:" "Support Team:" "SupportTeam :" "Support Teams :". All have small difference, but were applied for the same reason. It would be safe to assume that the same issue would happened with a Development/Operations team defining it at Source.
We discovered this issue when trying to create segments for the Smartscape 2.0 app, and based on recent feedback, I was told that I may just have to live with it.
I wanted to get everyone elses thoughts on this before I escalate it through our CSM, as maybe I am expecting something to exist that should just not exist anymore.
Thoughts, please..
5 REPLIES 5
siavash1996
Helper
Being brutally honest, the whole rollout of Segments, removal of tagging, and IAM has been a trainwreck. No idea why Dynatrace seem to be plugging their ears at all the negative feedback they've been receiving on these things. I understand that this is a transitory phase for the platform, but we're not shelling out hundreds of thousands of dollars for a transitory product, and so if these product shortcomings remain in Gen3 in the long-term, I can't imagine myself continuing with using Dynatrace for an observability platform.
macotech
Frequent Guest
Wow I'm glad we are not the only ones having these concerns. This transitory period is getting way too long waiting for the features that were lost to be reimplemented in the new version. The worst part is for features that will be permanently lost like Automated tagging. It doesn't make sense. Their alternative solution to tag at the oneAgent level does not solve the problem. In our company its very difficult to force all people deploying servers and other assets to monitor to always put all the necessary tags and follow the established naming convention. Its better to be able to do it centrally when possible. What about Custom Devices from extensions? They don't have a oneAgent. And for Azure resources that don't have a oneAgent? Automatic tagging can handle all these cases in a easier, cleaner manner. So why are they removing that feature?
alois_mayr
Dynatrace Advisor
Dynatrace Advisor
Thanks for the detailed writeup and feedback.
I understand the frustration and the lack of proper communication. Over the last few quarters we've been working on addressing most of the pain points you described in your feedback which will enable you moving to latest Dynatrace.
Central configuration of primary tags:
That's the most important update for you. We're releasing a central primary tag configuration in CQ3 that works across OneAgent, Kubernetes, and cloud providers. You define rules centrally in Dynatrace (similar to auto-tagging in classic Dynatrace) and our components will make sure your data is enriched properly based on that config. No need to chase down individual teams to instrument at source. It will cover the majority of use cases that classic auto-tagging handled.
Extensions:
OneAgent-based extensions follow those same central rules automatically. ActiveGate-based (remote) extensions will require primary tags configuration during rollout (ie. when you set up the extensions).
Tag normalization:
The new model actually handles this better. OpenPipeline will have a primary-tags processor that lets you streamline tagging keys, eg. mapping "Support Team", "SupportTeam", "Support-Team", “supportTeam” all into a single primary_tags.supportteam. It will do it across all signals. Expected next few weeks.
On the broader rollout communication:
The criticism is fair. We haven't communicated this well enough and thus it feels a bit like a construction site. The decision to shift to primary tags was grounded in real architectural benefits, while also addressing needs from large scale customers for data segmentation, data routing, access control etc at record level. At the same time, we understood customers need a central way to control enrichment. The central config coming in CQ3 is a result of that feedback.
General guidance for tagging going forward:
Follow the documentation (Organize your data with primary Grail fields and tags) on how to deal with primary tags in latest Dynatrace. It is the basis for defining Segments (global filters) across all signals (metrics, spans, logs, events, topology,...), access control (IAM via security context), data routing etc.  We're updating the docs as features ship, so the "coming soon" placeholders will be replaced with actual guidance and examples as each piece lands.
Alois
Thank you for the feedback/write up, Alois. This all sounds promising and I will look forward to the rollout of it.
Quick question: CQ3 being "July, Aug, Sept"? Or does it follow Dynatrace's FY, which would make CQ3 "Oct, Nov, Dec"?
You're welcome. Also looking forward to the rollout.
CQ3 is calendar quarter 3 - July-Sept.
